Trailer Valet TVDA Drill Attachment
T_BDancing
Member Posts: 85
Has anyone done their own mods with a drill bit to be used with a powered drill on a Trailer Valet 5X?
(Amazon)$45 is pretty steep to me for a drill bit and the reviews are not even that great.
https://www.amazon.com/Trailer-Valet-TVDA-Drill-Attachment/dp/B077TZW8YW/ref=mp_s_a_1_1_sspa?
I may need to use one of these bad boy Travel Valet 5X due to a tight driveway from a single lane 2 way street, with parked cars next to the driveway and across the street!
Thank you.
Thank you.
Tent to trailer w/TV: 2019 Jeep Grand Cherokee High Altitude 3.6L
2019 Tab 320 S Boondock Edge and get me out of NYC!!!
The Trailer Valet unit I bought (different model) came with the drill adapter. You should not have to buy one unless you lose the factory-supplied one. I have been using this model Trailer Valet - https://www.etrailer.com/Trailer-Dolly/Trailer-Valet/TVXL2.html. It does NOT stay attached to the trailer, which is the way I wanted it. It stays home and I use it only to move my 320S around in a tight area where we keep it stored at home.2018 T@B 320S. 2017 Toyota Highlander AWD
@tombeaux, thank you for your input and recommendation. I also like the XL for it to be able to haul it from the middle of tongue instead of the side like the 5X.
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
