Brakes or axle locking on 400 occasionally?
idletab
I've taken our 2019 400 on around 2,500-3,000 miles of towing and camping this year, and two times (both near my house, oddly enough) the passenger side brake (?) doesn't release. This happens after I bring the trailer to a stop. The trailer sort of hops/squeals and obviously isn't happy. Luckily it was only for a few dozen feet in my neighborhood.
Here's the odd part - once I back up a little bit, then continue forward, the issue has so far resolved. Makes me thing it's a brake issue but I'm not sure. Note that the wheel locked even when I hopped out and disconnected the brake cord, but after backing it up just a few feet it would roll as normal again.
Wheels/hubs are warm but we live at the bottom of a very steep hill so brake heat is expected. Breakaway cable is intact.
Any ideas on what's going on?
Also - how much camber is normal on a 2019 400? Mine has a bit, it's not crazy but it's there.
Lastly, I have adjusted the brakes, about 500 miles ago - to a very "light drag".0 -
Which brake controller do you have? It may need to be "recalibrated" or set up again.
I have a Tekonsha Prodigy RF - however, I hopped out of my truck when this happened, disconnected the brake cord, and it was still locked. Only backing it up a bit and then proceeding forward helped.0
Sounds like a broken return spring on your leading shoe within the brake drum to me. Backing would free that up. Time to pop the drum off to take a look...
Roger and Sue Hill | 2020 T@B400 Boondock (Cryst@bel) | 2022 Land Rover Defender 110 - P400 | San Juan Island, WA2 -
- 144 Events & News
- 414 Service/Maintenance & Recall Notices
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
