Tongue storage under $100 w/ pictures by Dale Helman
lkc001
Member Posts: 877
@Dalehelman I am interested in this mod you did with the Harbor Freight Cargo Rack. 1. What/where did you do extra welding? 2. Did you have to use a special drill bit to drill through the frame? 3. Your original post said you had to do some cutting. What did you have to cut? 4. How much weight do you think you put on each side in the totes? and
5. Does it get in the way of your dump handles or the dump pipes? Do you have to get down on the ground to reach them or attach your dump hoses?
Thanks for any info!
2018 Tab 400
@Dalehelman Are you around or are you camping??2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab -
@Dalehelman I finally saw you around on another post this morning! Did you see this question directed at you?
2018 Tab 400
- 919 Introductions
- 74 Teardrop Groups & Links
