Canopy frame scratched TAB finish
JP2558
Member Posts: 248
We use a Coleman 12x12 canopy over our clamshell, and last week’s 3 day trip included a lot of wind which enabled the canopy frame to occasionally rub against and scratch the finish of the open clamshell. Anyone with any thoughts on how to erase the scratches? They aren't significant, basically just cosmetic blemishes, but it would be nice to remove them.
And since this was our second outing, we also managed to close the hatch while (we think) one of the kitchen cabinet doors was open, so there is a ‘dent’ on the inside of the clamshell hatch, and we are now wondering how to repair that as well.
Thoughts?
Thoughts?
Thanks, Jerry
Try wd-40....and I am not even kidding. You can use that and a rag and try hand buffing them out. I haven't tried this with the T@b but it did work on my Jeep.
Depending on how deep the scuffs are...automotive rubbing compound. Auto parts store in the wash & wax section.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
I've used plastic wood (almond color, I think) to fill a couple of dents but I can't promise that's the best solution as they're still visible (at least to me, because I know they're there). I've thought about covering them with some cute graphics.JP2558 said:
Thoughts?San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
Thanks for the suggestions. WD-40 didn't work so I will next try the automotive rubbing compound. And I really like the suggestion for Plastic Wood!
Thanks, Jerry
2019 Honda Pilot AWD and 2018 T@B 320-CS hanging out on the left edge of Lake Erie.0 -
@JP2558
You might try "Polishing Compound" first. Rubbing compound is somewhat abrasive and will leave a dull spot and require some finishing work anyway.1 -
@JP2558 I can’t help with your finish but I can offer help with how they got there. My 13x13 has 10x10 leg span and due to winds picking it up and campground regulations against using stakes I had to be very creative. Lots of towels and ball bungees were my solution! Good luck!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
Big fan of Meguiars products. I would try the Marine/RV M45 polish and if that isn’t strong enough go to the Professional M205 polish. Using a DA machine and foam pad for both.‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI0 -
Thanks for the suggestions. For this coming weekend I think we will simply move it out about a foot away from the hatch!
Thanks, Jerry
if its into the paint Nucamp will send you touch up paint for free. You have to request from a dealer and send photos but they mailed it direct to me.2
we use those pool tubes around places that could scratch out t@bJaynie and Larry - Palo Alto, CA - 2015 T@B CS-S - Expedition EL - Nights spent in "T@b Spirit of Holly" 97
(9/22/19/1
