Help! I need advice on interior wall surgery
@Benita
This issue came up on the T@B Facebook Page in September 2019.
Tom Brooks Posted this reply on how to Remove the Rear Shelf Assembly:Hope that helps.It’s not that hard to retrieve. I retrieved an iPhone from there. You can go in from the top.
The bins under the hinged shelf are one piece of furniture. You will need the square head screwdrivers, I think just a #2 but maybe also a #1.
That unit has 2 or 3 screws on each side (passenger and driver’s side) that need to be removed plus screws on the inside front (hard to see, but you can feel them).
After they are removed, you can pull the bin unit up out of the area and gain access below.
It was a tight squeeze and we ended up having to remove the side panel on the driver’s side to get it out. (It is the panel covering the Alde glycol tank).
My wife and I took it apart, retrieved the phone and put it back together in about 45 minutes. Don’t even think about going in from the bottom. (After further thought, we might have taken the hinged top off first. If it needs to come off, it is pretty simple).
Adventures: 59 Nights: 411 Towing Miles 50,3502 -
@MuttonChops Very good description of the process to back in there--hopefully I will never need to do it, but glad to know it is possible without using saw blades
2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0 -
This tip rescued my iPad. Process went as described except we removed the hinged top (just made things easier). Thanks for posting this.0
