Does anyone know of a good quality180 watt light bar I can purchase to replace the Nilight light bar that came with my T@B Boondock. I would would want it to fit into the existing brackets. I dont want another Nilight, that light bar didn't even last a year with hardly any use and it already has 9 lights out on it with several others flickering.
                2021 T@B Boondock 400. 2021 Toyota SR5 V6
0 ·
Don't mean to hijack this post but dCliffhanger, does your light bar have condensation? Thanks.
2019 Tab 320 S Boondock Edge and get me out of NYC!!!
Springfield, MO
I had a problem with my Nilight bar and contacted them about it. They were most courteous and sent me a new one. No fuss, No muss. Just an FYI.
Many companies make, what are called, a 52" light bars but I would be surprised if any would mount with the exact same mounting spots. My Nilight is about 51.25" without brackets, but as you can image different lights could well be that .25" or so different, which would impact mounting. However, if you find one that is slightly smaller than the Nilight you can use some nylon bushing (local hardware store) to fill the gap. They come in a verity of sizes so you can mix and match to get what you need. I have used this method myself.
I would recommend that you select 2 or 3 52" bars from Amazon and see if any work. Many brands use very similar mounting brackets ( my experience with 3 different brands). Great thing about Amazon on most things...Free returns. Just print the label and drop off at UPS.
Hope this is somewhat of an answer to your post.
