Using compressed air for Winterizing is GREAT!
riooso
Member Posts: 27
Have a T@B 400 and done winterizing using the anti-freeze method. This year I tried the compressed air method. Dropped my pressure to 40psi and it was so easy and effective that I can't believe it. I was thinking that 40 psi would probably work but not very well. What I found is the pressure "blows" up the water tank a bit and you get a great burst of pressure when you open the facets. I will simply not go back to the anti-freeze way again. I live in a climate that doesn't drop below 25 degrees so I know it will work. Antifreeze might help the pipes in weather below zero if you live in that kind of climate.
3
Be sure to use RV antifreeze in the “P” traps.
- Hash T@B Fun
3 -
Thanks guy.... yes you are most correct I did.0
My trailer is out west right now and I used a 12 V DC portable air compressor to winterize my 400. But I agree, it’s an easy way to winterize the trailer. I’ve also used a larger compressor and have used a bicycle pump too. I follow it up with pink RV antifreeze dumped down there sink, shower drain and toilet. I empty 2 gallons of the pink into gray and black tanks.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1
- 31 "FOR SALE" - New/Used Trailers
