Contortionist
Tampakayaker
Member Posts: 558
Is it just me, or do you need to be some sort of super flexible/agile person to store items behind the folding seat back on a 320S?
Is it normal for the seat back, when folding it forward, to hit the bottom corner of the window frames and not fold all the way down flat?
Just a little more clearance and it would seem that it would be a lot easier to reach things behind the seat.
Tampa FL
Tampa FL
@Tampakayaker I thought you were posting about checking the glycol level!
I find getting to the passenger side easiest from under the seat storage area. The drivers side is trickier. I actually don’t use that side anymore, and now leave the couch back down as I sleep wheel to wheel. I have seen some prior mods on the Forum though. Good luck! 2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
I use a trash picker/grabber for those times I can't reach all the way down there. I keep it in the storage area under the passenger pedestal seat (behind wood door near the fire extinguisher). They now make telescoping models so you don't have to open the cabin door in order to get it out. About $11 on Amazon.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
Come Spring we are going with the @JanandDave solution --
https://tab-rv.vanillacommunity.com/discussion/10380/split-the-seat-back-or-not
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0
- 957 Air Conditioning & Refrigeration
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
