I just accidentally bumped the plastic storage bin on the front today and it moved several inches. Upon closer look, I found that two of the three screws that attach the plastic tub to the frame were totally sheared off! The entire tub and propane tank were literally only hanging on by one screw!!! First, I can't believe only three not very big screws are all that attaches the tub (80+ pounds counting the tub, tank, and mounting frame) to the frame in the first place! Of course part of the screw is still screwed into the hole, so that has to get drilled out to repair. My concern at this point is I don't want to simply replace the screws. I think I need bigger and more screws! Please go out and check your screws!! If this thing comes off the frame, I hate to think what could happen. I emailed NuCamp about this serious matter. I will repost when I hear back from them. I tried to attach photos but I can't get them sized properly and I finally gave up.
TabbyShack said:One thing I'm wondering that someone might know....are the screws supposed to first go through the metal propane tank support bracket, then through the plastic bin, and then into the trailer frame?...
I buy from TAP Plastics but I don't know how much they want for shipping if you're out of their service area.TabbyShack said:I love the HPDE idea. I will definitely look into that.
