Standard Yakima Roof Rack on 320S
fishergary
Member Posts: 12
I have a 2019 Tab 320S and am planning on adding a roof rack like the Outback/Boondock models to use for solar panels. I would like to buy used standard Yakima components to keep the cost down. I found a pair of standard 59" Yakima tracks on Craigslist which I would like to use. I contacted Yakima, and they assured me that the standard rails could conform to the ~100" radius of the T@b with no problem. NuCamp, however said that the racks used of the Boondock are non-standard. The question I have is regarding the actual profile of the track extrusion profile. On the standard Yakima tracks, the top of the extrusion sits at an angle relative to the bottom (see picture). Can someone with a Boondock edition Tab 320 look at their rack and let me know if the extrusions have an angle, or if the top surface is parallel to the bottom?
On my 2019 Boondock w/factory racks I used a combination square to measure from the roof surface to the top of the track. The inside and outside edge both stand 9/16" proud of the roof. This indicates to me no angle.
Hope this helps...
2019 320 Boondock Edge - Sold Jan 2022 -
CrabTab - Thanks for checking! Looks like I'll need to order the factory roof rack from NuCamp.
- 919 Introductions
- 74 Teardrop Groups & Links
