Welcome to the Forums....there are a couple of mentions listed in these threads. (You may need to dig through the thread for the specific vehicle.) They are several years old......
Does the vehicle you are considering have the factory tow package? For 2014 that would be a receiver hitch and 7-pin connector . . . both can be aftermarket added. 2014 QX60 also are pre-wired for an electric brake controller. Which is good. You might need to purchase the wire harness if original owner lost it.
Vehicle owners manual is available on-line. It has several notes that various driving safety systems should be turned-off while towing a trailer. . . . also states the vehicle is designed for passenger use not towing . . . my read on that is stay well under the tow rating of 5,000# ideal conditions maximum tow a T@B 320 not a T@B 400.
'18 320 S, pitched axle, 3020HE; PNW based TV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller Adventures: 57Nights: 399 Towing Miles 49,190
