FRESH WATER DRAIN LOCATION
CLAYTAB
Member Posts: 10
Just purchased 2015 320s. All manuals etc. say that the fresh water drain is located drivers side corner front by dump valves. I have no drain there at all. I did see some kind of outlet (looks like a air hose connection) down by the side step. My question is: Is this the fresh water drain, and how do I open it?
Yes, the fresh water drain valve is just in front of the passenger side wheel. It should have a valve handle to turn. I will look for a picture.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Thanks, valve must be broken off, because there's nothing I could see to turn, Very hard to get to location also!!!
Yes, someone else had this problem. They were able to use a pliers to turn it, but had to replace the whole valve. Bad picture that I expanded from the manual. You can see where the step slides, too.
Yeah, I didn't see any black knob to turn... guess I need to find out how to fix.Here we go, already had to fix leak on Alde hose fitting, buying used is always an adventure. Glade to find this GREAT source of knowledge.0
this is in a 2020 320-s
(Edited for photo size.)
2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E0 -
- 144 Events & News
- 415 Service/Maintenance & Recall Notices
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
