How to remove/replace Alde glycol drain plug?
Photomom
Member Posts: 2,217
A question for those who have replaced your Alde’s glycol. My T@B is late 2016 and the drain plug is brass, held in place by some sort of black clamp - see photo. How do I remove the clamp, and equally importantly, how do I replace it?
(Photo size reduced.)
I think there may be special pliers for those clamps, common on autos. However you can use any pliers if you are careful. These things will take flight if they get away! Best to squeeze with pliers and move UP one hose off the clamping area on the plug. Leave it up there and then pull the plug2019 T@B 400 Boondock Lite2
Thanks, I did finally manage to get the clamp off, glycol drained, and plug and clamp back on. Just pinched my fingers once. Purpose designed pliers would probably help.John and Henrietta, Late 2016 T@B S Max in Western New York1
Hi @Photomom, I came across your post trying to find the drain plug for the Alde system and noticed you have the same year Tab as we do. Do you mind telling me where to find it / how to get to it?
Update - nevermind I found it!!2016 Little Guy T@b M@X S - new owners from Centennial, Colorado!! 🏕️0 -
Look under the drivers side, behind the tire. Unless you have a CS-S, not sure where the Alde drain is on that.Seja said:Hi @Photomom, I came across your post trying to find the drain plug for the Alde system and noticed you have the same year Tab as we do. Do you mind telling me where to find it / how to get to it?John and Henrietta, Late 2016 T@B S Max in Western New York1 -
This is the type of flat band hose clamp that Alde sold.
https://www.amazon.com/Automotive-Repair-Installation-Removal-Ring-Type/dp/B085FTNH4Q/ref=sr_1_16?dchild=1&keywords=wide+flat+band+hose+clamp+pliers+automotive&qid=1592677417&sr=8-16
Kay and Tom - SW Wisconsin - Silver T@bernacle - 2018 T@B 320S Boondock Silver/Black trim TV, 2018 Chevy Colorado, Silver/Black trim, Duramax, TowHaul, IntelliHaul0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
