TAB Boondock Edge with lightbar
Nacovi
Member Posts: 6
Hello, new TAB 320 owner picking up my trailer Wednesday. We are barely able to fit hight in our garage. Does anyone know if lightbar is the high point or if the vent still is?
Debating having dealer remove bar prior to us picking it up. Would love to keep it if possible. Any insight appreciated
They are very close to the same height. We added a vent cover to allow the vent to be open in the rain. The vent cover is now the high point on our Boondock Edge. Hope this helps...
2019 320 Boondock Edge - Sold Jan 2022 -
Thanks for the feedback CrabTab. I cannot quite tell from pictures as the Tab is a bit of an optical illusion with the prior high point being the vent cover. I have asked the dealer to measure but we are dealing with a fraction of an inch even with an airdown to about 8 PSI so a little nervous about the light bar.
It stopped raining outside, so here is a pic looking straight on from the front. Without our vent cover, the light bar IS the high point.
That was my fear, thank you SO much for taking the time to do that for us. VERY cool and much appreciated
They say to add in 4 inches for Boondock package but I do not believe they count that light-bar as part of the 95"
light bar is higher on our 2020 320-s Boondock
2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E -
Thank you so much TrimTab. I was going to have dealer pull it but am told it is all quick release and I can easily pull it when I get home. My friend bought a Boondock light with same garage and had to drop tire pressure to 8lbs to fit so I think the light bar may be a deal breaker (unfortunately)
Does it look like quick release?
Allen wrench and open end for 12v connection, easy.
thank you!
- 953 Air Conditioning & Refrigeration
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
