Cushion Cleaning
07Dutchman
Member Posts: 2
How to clean the 2007 TAB cushions,
Can they be dry cleaned? if so, do you remove cushions or leave them when sending to dry cleaners.
any other methods?
Thanks
any other methods?
Thanks
@07Dutchman, I'm sure some of our resident experts will chime in soon, but I would remove the covers to have them dry cleaned. The cushion(foam) may be sensitive to the chemicals in the dry cleaning solution and thus degrade what is already getting to be old foam. But, I do concede that cleaners who come to your home do clean upholstery with the foam cushion inside the cover. Good luck with this!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
- 916 Introductions
- 72 Teardrop Groups & Links
