Exterior solar port installation
Michael49
Member Posts: 140
I would like to add an exterior solar port for my suitcase solar panel on my 400. I Purchased this SAE mount. I plan to install it just in front of the storage bay door. I’m curious if anyone here would have any recommendations on how to install this? Would you make a hole just wide enough for the inner diameter to fit through? - see photos. Would you use butyl tape to seal it? any other recommendations?
https://www.amazon.com/gp/product/B07TMMJMVP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.
Drill just large enough for the inner diameter so you have room for the two screws to take a bite. Be generous, but neat, with sealant. Butyl tape is neater than using the caulk and you should be able to cut away any excess. Wear rubber gloves.Verna, Columbus, IN
I am interested in the same mounting procedure. I saw some pictures somewhere, but can’t seem to find them again. We have been researching suitcase solar for our T@B 400. I saw some pictures about connecting to the wiring for the cutoff switch just inside of the storage box door... Can someone help... Thanks...0
20 T@G XL Boondock and 2019 Ford F 150 4x4
Madison, Wi1 -
Thanks....0
I used marine through hull sealant all around the socket and under the flange. I also screwed it on. I drilled the hole to the left of the heater access door outside. In my 400 it is fairly close to my added controller and batteries under the bed.
A little nerve racking, but got it done yesterday - thanks for the help guys.
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
