2021 320S spare tire access
Snohomish WA, 2024 3.6L Grand Cherokee
managed by VE Smart Network
I used the stabilzer jack handle (stored under the passenger side wheel well compartment) as the extension and wrench for the spare tire. It fits over the supplied socket (3/4" hex on the top). You're right, the socket is a tight fit onto the spare tire lowering nut but it did work.
When I put it back up, I find I have to raise it until the tire contacts the frame, then use my foot while sitting on the ground to push it toward the rear so that it sits level when raised. It usually takes me a couple tries.2021 T@B 320S Boondock - 2018 Toyota 4Runner1 -
Duh, didn't think about using the stabilizer bar and the adapter. I'm not sure I would have thought of it during the stress of a flat tire. Always nice to display dumbness on the forum. Though the sticky adapter was tough to remove the one time I tried it, I'll want to wear it in I guess as I don't want to be cursing the nut with the hassle of changing the tire. Thanks
Though your comment on storing the stabilizer handle reminds me of the other minor rants on the 2021 why did NuCamp remove the door into that compartment - I hate having to raise the bench to get in there. The door was convenient to access chocks/leveler/handle/hose/cable. Also why leave a 2-3 inch toe grabber beside the bench? My wife and I both have tripped on this. Otherwise we love the changes.
managed by VE Smart Network1 -
please read the caution on the side of the tongue. No drills are to be used to lower the spare. One owner has already broken the raise/lower assembly by using a drill.Verna, Columbus, IN
I saw that and was using the screw driver torque limit feature. But good to remember!
managed by VE Smart Network0 -
Not yet but I have grumbled that the side I use for storage of hose/cable/leveler requires I lift the back seat whereas the driver side doesn't. Haven't looked into it though. If there're 2 there's more! I'll need to be more careful.
@zanth, I had the screws pull out of the passenger seat access door as well. It ended up being a piece of 1x3 that the sliding slats are attached to was binding with the lower frame. I used a block plane to bevel the last inch or 2 of the 1x3 so it wouldn't hit the lower frame and instead 'feed' smoothly into location. I also moved the hinge over 1/2" and I haven't had any problems since with the screws coming out. It was a small adjustment but a big improvement.2021 T@B 320S Boondock - 2018 Toyota 4Runner0
Thanks for the update, I haven't had the problem as much anymore. I was thinking the parts needed wearing in a bit. Maybe it's as simple it wears in or breaks
But I'll look at it more closely now with this in mind. Snohomish WA, 2024 3.6L Grand Cherokee
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
