We’re planning to buy a new TV soon. The Toyota Highlander is high on our list, but we’re also curious about the Kia Telluride and Hyundai Palisade (both highly rated by Consumer Reports). Anyone have have experience with either of these vehicles?
Many thanks!
Bill & Sharon
New Mexico
2021 T@B 320s (“T@Bañita”)
2023 T@B 400 Boondock (“Redwing”)
2020 Subaru Ascent (“Bubbles”)
1 ·
Here's one comparison..
https://allcarvideos.net/2020/02/12/kia-telluride-vs-subaru-ascent-2020-suv-comparison-test/
Highlander has been at the top of our list too, but probably not anymore.
I love Toyota and it was my first choice until we did the features comparison. Hard to go wrong with a Toyota. We have had success with both brands.
Either way it was a tough choice but I feel really good about the one we made for us.
Hope you can take your time in deciding. Lots of research and Good Luck
Backup is the 2020 Hyundai Tucson Limited 2.4L, 181 HP (avg 15-18 mpg)
SC to Southern Ca. - Flagstaff - Home. Many trips to the Appalachia's. Still going
2019 T@B 320 S
If you listen carefully, you can heart the petroleum CEO's giggling
Well, we have been able to tow the 400 BD well with the Telluride, using a 4500# weight rated Fastway E2 weight distribution hitch to increase our comfort and confidence in towing the 400. But, without the weight distribution hitch engaged, our Telluride rode low in the rear while towing the 400. And, the lightened front axle felt a little light in steering, although still relying primarily on drive from the front wheels. I am not experienced towing trailers, but wasn’t keen to gain more towing experience under these circumstances. I never felt I was about to lose control and experienced no trailer sway, but never felt comfortable with a towing combination I felt was not properly balanced. I never drove faster than 55 mph with this TV/tow combination.
For us, the weight distribution hitch was the answer. It’s not just a matter of feel. Distance from the wheelwell fender above the wheel hub to the ground when the Telluride is unloaded is 32”. When the Telluride and 400 are loaded for camping, hitched up, and the weight distribution hitch is engaged, the Telluride sits 1 inch lower at the rear measuring point. Add one passenger, and the difference is 1/2”. Add the driver, and I think both measurements would have been 31”.
When measured on a CAT scale, the tongue weight was 420#, with the front tub loaded with 1 propane bottle,60% full, and one set of Anderson levelers, 5 stabilizer pads, the black/grey water discharge hose, a slinky, and a black water garden hose and connectors, plus various gloves and sanitizing wipes. I also added a Husky 3000 lb electric jack to the tongue, which weighs ~24 lbs more than the standard manual BAL trailer jack.
All three axles were well within published weight limits-the drive axle weight measured was only 60 lbs heavier than the steering axle measurement, and the trailer axle weight was 680 lbs below the 3900# gross weight/trailer axle weight limit.
I now keep my speed below 65 mph, but using the weight distribution hitch am far more comfortable with the handling and responsiveness of the tow at this speed than I was driving 10 mph slower without the weight distribution hitch engaged.
So far so good towing the T@B 400 with the Telluride in the hills of North Georgia, and the Pine Belt of South Mississippi. I’ll revert if anything changes, but am confortable towing the 400 with a Telluride, assisted by the weight distribution hitch.
