TAB 400 2021 ALDE Glycol Refill Location (Boondock)
Giota
Member Posts: 59
Can someone tell me where the 2021 TAB 400 (Boondock) ALDE Glycol refill location is located? In the future it might be a good thing to know.
I believe it's in the drivers side porthole window2
You are exactly right! Thank you for the Quick Response Tabfortwo!0
@Giota
And in case you haven't already figured this out, the panel covering the glycol canister is simply secured by 4 keyhole screws...Just slide the panel up about 1/4" and the panel can be pulled out over the screw heads.2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000
2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller2
- 424 Service/Maintenance & Recall Notices
