Pots and Pans that work inside
CxMain
Member Posts: 4
We were a bit surprised to discover our cookware used on a propane stove while tenting didn't work as well inside the camper. Our old stuff was too big to use two pots at the same time inside and too thin for butane heat when cooking outside.
All purchased from Amazon:
This new combination of 4 pieces has proved to be great choices for the way we cook & eat -
good quality to handle the heat of the butane when cooking outside,
taller and not as wide so any two can be used at the same time on the inside,
handles stay cool, and the pots have markers on the inside for cup measurements,
and everything has lids for no-splatter cooking.
-Norpro KRONA Stainless Steel 12 Cup Multi Pot with Lid
-Norpro KRONA 8 Cup Multi Pot with Straining Lid
-Norpro 1 Quart Stainless Steel 3 Piece Mini Steamer Cooker Set
-Simply Calphalon Enamel 8 Inch Covered Omelette Pan, Black
2015 T@b S Max / 2015 Jeep Wrangler Unlimited / Gilbert, AZ
Patti, that looks like a fantastic set.
Last year we investing in an expensive set of pots and pans, plates and cups, from REI. It is something like 15 pieces that all stack into just one, single unit that goes under the stove. I love the set, they are very nice and heat well and evenly, but they are a hassle to take apart and put back together. Those Eazistore pans look like an excellent solution.
Sterling, VA
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
