SeeLevel II Tank Monitor
Catie
Member Posts: 5
I have a 320 Outback 2017, and the monitor has worked fine for the last 3 years. Suddenly, I get no display reading whatsoever, but do get the water pump green light. The fuse appears fine. Could it just be the display board and I need to replace it?
@Catie, sometimes the wires attached to the back of the seelevel board come loose. Check that first. I think it's just removing 4 screws and gently tipping the board forward to observe the back. Don't try to pull the board forward and out of the wall until you see jow much extra wire (slack) you have. Good luck.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
Conversely, the lads at the sending units could be bad... do you get no readings at all( battery,FW,gray & black)
?TV- '16 Chevy Colorado LT Crew Cab-DuraMax
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
