How do you reattach shade anchors?
Sam452
Member Posts: 19
Of course, you just screw it back in. Except, I’ve done that. But I’m finding that replacing it with a larger or longer screw can only get you so far (too long of a screw punctures the outer shell). The soft wood of the frame isn’t helpful as it’s terribly easy to bump it out again.
How do others keep their anchors in place given that the screens get ripped out.
This is my front window which holds the luggage. My 2008 CS T@B doesn’t have much storage space for stuff. I’ve searched the forums but haven’t found similar issues.
T@B CS 2008
Put toothpick or matchstick pieces in the hole with some wood glue. then you have something for the screw to bite intoCarol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL1 -
@Sam452, what @Mouseketab said 2X. Also you might try to fill the hole with an appropritely sized dowel and wood glue it into place giving the screw a solid place to bite into.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
That this picture to local hardware store. They are for hollow core doors. Perfect for thin paneling.(Edited for photo size.)
- Hash T@B Fun
EZ anker there are all kindsT@B 400 , Tundra0
Thank you all for the pointers! With your help, I was able to get it resolved.T@B CS 2008
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
