Rear Camera
huanvanho
Member Posts: 48
I have 2017 T@B 320. I want to connect a rear view Camera. I need to find 12 Volt DC to power the camera. I see there a lamp at "license place". I want to tab in this circuit to power the camera. I removed the 2 screws that hold the lamp but I can't pull out the lamp. I did not want to force it because I am afraid something may be broken. Any idea?
thanks
thanks
If you use that as your power source. Just a reminder you will need to drive with your parking lights or head lights on.
- Hash T@B Fun
Thanks.. I am OK with that. That is the easiest place to get power without too much wiring. Now I discovered my lamp for license place is full with water. Can I buy this lamp online?
Did you ever find a resolution to this? Same problem with the wire...and the water in the light.Thanks.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
