12v Outlets
webers3
Member Posts: 436
Had 2 phones in need of charging plugged into the USB outlet of my 2017 320s, after few minutes the outlet and USB connectors got quite hot to the touch and the power to the phones was cutting in and out. It appears the 12v outlet can't handle multiple devices, what is the power output of the 12v outlets? Thanks in advance
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
Don't know the specifications for units installed in T@B.
eTrailer has one that looks the same and it's specifications are:
'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
I had the same experience, @webers3.
See here for what I did.. (scroll down)
https://tab-rv.vanillacommunity.com/discussion/8902/rear-usb-ports-dead-replaced/p1
Thank you so much @BrianZ, this is what i will do2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
