T@B 400 Window
RayJim
Member Posts: 146
What is purpose of the clear plastic tape on the trailer below the windows?
2021 T@B Boondock 400. 2021 Toyota SR5 V6
A question that I had when checking my rig. A couple of mine got wrinkled and damaged. Easy to fix see the discussion here:
https://tab-rv.vanillacommunity.com/discussion/10947/clear-plastic-on-body-under-corners-of-front-and-back-windows-what-to-do-when-they-get-damaged
2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab -
@RayJim
The protective film is there simply to prevent the windows (when closed) from scuffing the trailers finish.2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000
2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller -
Thanks order some clear film that was recommended in the discussion to fix.2021 T@B Boondock 400. 2021 Toyota SR5 V6
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
