Weak Propane Performance on Norcold N180.3X
tombeaux
Member Posts: 63
We have been fortunate that our Norcold 3-way has worked well under frequent and heavy use on both shore power and propane. On the last two trips, it seems weaker on propane. When I light it, the indicator that is supposed to cross from white to green after a few minutes only travels to the line dividing the two colors. It is lit and there is heat coming out of the outside vent by the door, but I am wondering if there is some restriction somewhere. Any ideas? Photo attached to show where the indicator parks. 2018 T@B 320S. 2017 Toyota Highlander AWD
Mine also stays at the line dividing the colors, it has done that from the beginning but it works just fine
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut0
- 418 Service/Maintenance & Recall Notices
