Victron Question
NoVaGuy
Member Posts: 95
I believe that I now have my victron battery monitor properly set up and working correctly. I understand there is another Victron controller under the bed that monitors the solar charging. Is there some way to see the display other than crawling under the bed? I am trying to connect that controller to my IPhone and it is asking me to read a code.
2020 T@B 400 BD Lite
@NoVaGuy: the 6 zeros didn’t work? I didn’t have an issue connecting to my solar controller, however, I bought mine on line. I have heard on this forum that there is/may be an access code on the back of the controller and if so(6 zeros doesn’t work) then you’ll need to remove the solar controller to get it...😬TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback1 -
I didn't see in the Victron manual if the controller powers down if limited solar voltage is sensed. I have two controllers attached and I've noticed a parasitic drain of about 10 watts - this hurts if no sun is available. In our shady / cloudy PNW this is like leaving the strip lights ON all day and night. I'm thinking of installing a switch to disable these if the trailer won't be getting sufficient sun. Anyone know of a setting on the controllers? Even switching OFF the battery switch will leave this load ON.
Snohomish WA, 2024 3.6L Grand Cherokee
managed by VE Smart Network0 -
If you turn off the trailer you still have a parasitic drain? That does not sound normal. Send pics of your Victron screen with the battery off.@NoVaGuy Do you have a Victron Shunt? Or just a Victron Controller with the Victron App?
I am not having a problem with the Victron Solar monitor, my question was, can you see it without crawling under the bed.
2020 T@B 400 BD Lite0 -
I think the question might be "where is the Victron controller?" Some of the 400's had them under the bed, and others had them in a panel somewhere near the fridge? I can't find a post that explains where it might be in the different models.
@pthomas745 It is under the bed. My question remains, can you see it without crawling under the bed, say from the side access hatch. Looking about, I was unable to get my eyes on it.
I can barely see mine thru the Alde hatch. Mainly, I just see the blinky blue LED. It is mounted on the wall of the storage closet, below the bed.
To get a good look at it, I have to open the driver's side panel of the bed.
Different model years, campers with the 3-way fridge or solo bed may be different, I don't know.
2019 T@B 400 Boondock Lite, BMW X30 -
@NoVaGuy - I think the remote mounting was done because it was expected that you will access the controller and battery monitor information via Bluetooth. Have you been able to bring up that display on your phone yet?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@pthomas745 In answer to your question re my "parasitic drain": The battery switch has been off during the week and the shunt only shows a draw of 2 watts now with the switch still OFF. I suspect the controllers do go into a very low drain mode if the light is low. But since the solar panels can continue to charge the battery when the switch is OFF it makes sense that they also could contribute to draining the battery if they don't get sun. Obviously in most cases they do get some light to offset this (very tiny) draw.
managed by VE Smart Network1 -
@NoVaGuy, I lost my Bluetooth connection as well and the 6 zeroes method didn’t work either, so you’ll need to get the PUK number which is on the back of the controller - sorry. I have a 320 so the controller was easily accessible.Richie, Mickie and Satchmo
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium1
