We ordered our TAB CS and trying to envision backing it up our driveway and are worried
about the back of trailer clearing. NUCAMP said the angle of departure is 13 degrees. The driveway in 87 ft long with elevation at street of 69ft and 76 ft at the top. My calculation of incline is around 5.5 degrees. Will the trailer make without a problem when being towed by Jeep Wrangler or
Subaru Ascent? Sorry for this basic question. New to
camping world and Nucamp.
sue
0 ·
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
. . . however that is just an opinion based on several assumptions and estimates of
the TAB CS dimensions. As I don't have access to a CS model to measure I used CS
Pictures to estimate the trailer axle location. An estimated trailer axle location plus
NuCamp reported 13 degree departure angle calculates out to about 15 - 16 inches rear
ground clearance on level ground. That sounds reasonable as a standard CS has a 15
inch hitch/coupler height.
So with those limitations in mind my guesstimate is you will have more than enough clearance.
Final Note: Above only addresses trailer rear. It is possible to drag either the front jack post or TV hitch depending on your TV and hitch.
