Little Red Fire Pit and T@B onboard propane.
ChrisK
Member Posts: 280
Has anyone used the outside propane connection on the T@B 400 to run a Little Red Fire Pit? I tried it on my daughter's 400 using a propane hose adapter and we got no gas. Yes, we had the line turned on and were getting gas out of the adapter hose if I pressed the center of the valve on the hose but no gas to the fire pit.
2014 T@b S Max AKA T@dpole
I don't completely understand most of this, but it has to do with regulators cancelling each other out in each device. Or something. This thread explains some of it, and there is a thread inside it that goes to a better explanation.
Towed by 2014 Touareg TDi -
Yes, that helped a lot. Thanks.2014 T@b S Max AKA T@dpole
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
