Internal TV Antenna
kimmerfnp
Member Posts: 19
I have a 2019 T@B 320 and have an RCA indoor flat antenna. Can someone explain to me where to hook this up on my tv? Thx in advance.
Kim
On the outside of the trailer where the radio antenna is, there is a "flap". Under that is the connector for an antenna or cable TV that goes to the television. You can take off the coax cable from the back of the TV and connect the antenna there, but the range of the antenna might be limited.A thread here with some photos:
Towed by 2014 Touareg TDi -
If you have the Nautilus system in your 320....this thread explains the connectors.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
