2021 TAB 320 S BOONDOCK tire clearance for Brahma lock
jonn
Member Posts: 31
Brahma says in order for it's wheel lock to work, the tire clearance for the 2021 TAB 320 S BOONDOCK must be:
- Ensure you have a minimum of 1.25” clearance between the rear sidewall of the tire and the trailer body.
- Ensure you have a minimum of 1.5” clearance between the tire and the fender.
I will be picking up my Tab in a few weeks and would like to have the Brahma Lock with me if possible as we will continue on up into Vermont after taking possession of the trailer.
Can any of you 2021 TAB 320 S BOONDOCK owners take some measurements to confirm what clearances do you have?
The factory has been slow in getting back to me on this one, thanks.
I'm in the same position - will be picking up a 2021 320S Boondock in early March. Did you get the Brahma and, if so, were the clearances OK?
@oldenough, @jonn hasn't been active on the forum since December. You might try a PM to get a response.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.1 -
A cordless angle grinder can get it off in 5 minutes, if they want to get it they will.
Best insurance is insurance!
2021 TaB 320 Boondock, Gran Cherokee TrailHawk0 -
Did anyone find out if the Brahma works on the 2021 Tab CS-S Boondock? I'd like to order.....0
