Inverter /breaker noise
Markfarver
Member Posts: 2
2021 400, I have a fan motor running while on shore power that has not happened before. Not sure if there is anything to do here? Fan noise coming from breaker/fuse pannel
2021 Tab 400 Boondock Honda Ridgeline
The converter is the brown box that you hear the fan running while on shore power. It is charging your battery and the fan will run until the battery is fully charged. It’s normal.Verna, Columbus, IN
- 917 Introductions
- 73 Teardrop Groups & Links
