Cabinet clear coat
Does anyone know what type of product the factory uses to clear coat the cabinets? I have a 2018 Tab 320 CS-S that has a little water damage to the upper cabinets in the galley. I've sanded the affected areas but I want the proper finish so everything matches.
2019 Jeep Wrangler 2 door and a 2018 Tab 320 clamshell.
  • Verna
    Verna Member Posts: 6,876
    An email sent to customercares@nucamprv.com will get you the correct answer from the source.
  • Marktab320css
    Marktab320css Member Posts: 21
    The first thing I did was email. I'm on a different timeline than NuCamp and wanted to get this done over the weekend.
  • Tabaz
    Tabaz Member Posts: 2,420
    I've had very good luck staining small repairs with Minwax wood finish penetrating stain, semi-transparent, natural 209. Their polyurethane semi-gloss clear coat works well with the stain.
