Cabinet clear coat
Marktab320css
Member Posts: 21
Does anyone know what type of product the factory uses to clear coat the cabinets? I have a 2018 Tab 320 CS-S that has a little water damage to the upper cabinets in the galley. I've sanded the affected areas but I want the proper finish so everything matches.
2019 Jeep Wrangler 2 door and a 2018 Tab 320 clamshell.
An email sent to customercares@nucamprv.com will get you the correct answer from the source.Verna, Columbus, IN
The first thing I did was email. I'm on a different timeline than NuCamp and wanted to get this done over the weekend.2019 Jeep Wrangler 2 door and a 2018 Tab 320 clamshell.
I've had very good luck staining small repairs with Minwax wood finish penetrating stain, semi-transparent, natural 209. Their polyurethane semi-gloss clear coat works well with the stain.2016 Outback 320
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
