2021 Tab 320S Boondock Height
William_Keever
Member Posts: 37
This coming Wednesday we are scheduled to pickup a new 2021 Tab 320S Boondock from a dealership that is an hour away, but I’m concerned that it will not fit in our garage that is 95 1/2 inches tall. Nucamp’s brochure states that the Boondocks are 96 inches tall, but the dealership is trying to assure me the specific unit is only 95 inches tall. Can several of you all withdraw the 2021 Tab 320S Boondock with 15 rims let me know the exact height of your unit while sitting on a hard surface such as asphalt or concrete. Don’t forget to include the fan if that is highest point. Thanks.
Sorry I posted this in the wrong category, but any insight would still be greatly appreciated.Also, does anybody know how to move this comment to the appropriate category? Can’t seem to figure out how to do that either.
It’s gonna be tight!! I have the same situation - 95.5” garage opening and a 2021 320 boondock. The first time, I unhooked the trailer, lowered the tongue, and hand-wheeled it in. It cleared by an inch or so. When I pulled it out I decided to hook the trailer up and have my wife watch. The plastic trim rubbed on the garage door gasket but cleared. So now I carefully back in or pull out while hooked up.Anyway, the height of the plastic trim and the fan cover are almost identical. On my trailer w empty water tanks, stock battery, and full propane but little personal gear the height is 95 1/4” as best I can measure. As I said, it’s gonna be tight but I think it will fit!2021 320S BD
2017 F-150
Coeur d'Alene, Idaho -
Great insight, Wayne. Thanks.
you can simply let air out of the tires, then air up when pulling out2021 TaB 320 Boondock, Gran Cherokee TrailHawk
I have a 2020 320S Boondock Edge. With the LED bar on top, it is about 8'-4".
- 916 Introductions
- 72 Teardrop Groups & Links
