Solar charging the battery when the TaB is covered
OlyCampers
OlyCampers Member Posts: 23
So we got the AllPro cover for our T@B 400. It occurs to me that with the cover on, battery won't get trickle charged by solar panels. I can eliminate any "ghost" power draws by using the battery disconnect. Any thoughts about leaving the camper connected to house 120V power while covered to keep battery charged? We'll be using the camper at least monthly, so it won't sit more than a few weeks between uses.
(Title edited for search purposes.  Moderator)
2020 T@B 400 Boondock Lite behind our 2014 GMC Sierra. Homeport is Olympia WA USA.
    pthomas745 Administrator, Moderator Posts: 4,530
    A fully charged battery, with the battery switch off, will hold a charge for months.  Just turn the switch off and you don't need to do anything.  You can use your Victron app to monitor the battery.....but, it won't do very much!
  • Michigan_Mike
    You could hook up a smart charger to the battery with a quick disconnect if you wanted.  A fully charged battery will hold a charge for quite some time and they do lose a charge over time which is a naturally occurring phenomenon.   It would be more efficient than plugging the trailer into shore power and putting wear and tear on the converter.   But as noted if you are taking the trailer out every few weeks and turning the battery off there isn’t much need to do anything.
    Other owners have reported that their panels receive adequate sun through their trailer cover to receive a charge.  Try it and see what happens.
  • OlyCampers
    Thanks all for the insight! Appreciate Moderator changing subject to make my post easier to search. Very helpful T@B Community!
  • Dalehelman
    For the last 6 years our trailer has been plugged in 24/7 when we are not traveling which is 90% of the time. We still have the original battery and converter/charger. I do unplug it for a day or two from time to time just to make sure the battery is still holding a charge.
    1. Hash  T@B Fun
