Victron MTTP info compared to BMV-712
rhyno
Member Posts: 393
I installed my BMV-712 and now it shows the Current and Power info but now the MPPT shows zero draw in the Load output section for Current and Power. Is this normal or do I have something miswired?
For reference, the BMV-712 is wired inline between the distribution block and the battery bank's negative pole. B1 is wired to the first battery's positive pole and B2 is wired to the first battery's negative pole. I followed the wiring guidance from the AM Solar doc to wire the midpoint monitoring cable.
When I turn my battery switch off, with no input power to the battery (shore or solar) my Current and Power read zeros.
I am running off battery and the BMV shows me pulling 4A, 120W. MPPT shows load at zero. I am in bulk charging mode so charging appears to be working fine.2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO0
... I think I figured it out but would like someone to confirm please.
It looks like the Load output section of the MPPT is for the monitoring of directly powered devices running straight off the solar panel. If so then that section should read zeros since everything powered in the Tab goes through the battery right?2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO0 -
Oh...the Load section...I missed that. Yes...unless you have some "small" 12V device wired directly to the Load outputs of the controller, then "Zero" would be normal.
Towed by 2014 Touareg TDi2 -
The "load output" terminals on the mppt are for an indicator light. Offhand I don't remember what the reference is for in the app.
Edit: not sure that tells you anything about it...
Here a discussion about it:
https://community.victronenergy.com/questions/23783/purpose-of-load-output.html
I have nothing connected to those terminals.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Yeah, what @pthomas745 said! Heh!
In the Victron documentation, they talk about various settings/uses for the Load Output terminals. Here:
https://www.victronenergy.com/media/pg/MPPT_Solar_Charge_Controllers/en/settings.html#UUID-3324d989-d2a8-cbf5-fdef-ec34e537176f
A_Little_T@b'll_Do_Ya1
