I wrote the company and mentioned blowing glass fuses. Marvin wrote and said that yes, they have a tendency to blow easily. He suggested that I could run my current ground on the Alde all the way up to the negative on the battery. That might help. Has anyone done something like this? Not sure about any of this... where is the ground etc...
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
0 ·
You can run a temporary ground wire to the battery to test to see if it helps.
Please call Marvin again and ask his advice on what gauge of wire to run, where to start with the wire at the Alde and then you can just lay the wire on the driveway to the battery's negative side to see if this helps.
Tell us us what happens, please.
I'd want to understand why Marvin thinks this may resolve the issue.
Page 21 appears to show the wiring seems to go directly from the fuses to the 12V battery with an additional 5V fuse on the positive side. It does not show a converter in the circuit, but the 5V fuse would probably be in the converter on the nüCamp T@Bs.
If the ground wire is loose or broken from the Alde, there would be inconsistent symptoms present. By running a ground all the way from the Alde to the battery, you would be adding a complete wire from the Alde to the battery, therefore proving whether the existing wiring is defective.
Now, I might follow up on Verna’s suggestion and get more info. I’m not feeling very comfortable with this procedure though. My timid response would be... I can carry spare fuses... grin..
T@bbey Road
Appleton, WI
Comments?
2016 T@B S Max, near Portland, OR
Photo Galleries www.pbase.com/jctangney
Wow... could this the cure for my occasional fuse blowing...?
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Thats is very true. I can easily say that it might be my fault..
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
https://www.amazon.com/gp/aw/d/B008OZ4U7C/ref=mp_s_a_1_fkmr0_1?ie=UTF8&qid=1526931456&sr=8-1-fkmr0&pi=AC_SX236_SY340_QL65&keywords=5+amp+so+blo+glass+fuse
T@bbey Road
Appleton, WI
Hey Terry,
T@bbey Road
Appleton, WI
Marc & Janet
2016 T@B S Max - 2017 Honda Pilot - Magnolia, TX
