Water Pump Runs Continuously
Just got done de-winterizing a 2021 320S.
With a filled fresh water tank, put in Dry Camp mode, turned on water faucets. Everything works OK. Water flows. Pump turns off when faucet closed.
But when I turned the water heater bypass valve to normal, then turned on the water pump, it runs continuously with closed water faucets.
There's water in the Alde tank. I drained a bit to make sure.
2024 Tab400 BD Black Canyon/ 2018 Jeep Grand Cherokee w/tow package / Madison, WI
