2018 TAB 400 Shower Leak
PaperDesign
Member Posts: 6
During the de-winterizing of our new to us TAB 400 I noticed two items in our shower. The cold water control will not come to a complete 'stop' when turned clockwise. Also water continues to drip thru the 'black' panel where the controls are located and into the shower drain. Is this abnormal? If so, any ideas on how to repair.
- Comments
Sounds like loose fitting behind black plastic cover. I believe that is easy to remove by taking out the screws on the sides2019 T@B 400 Boondock Lite
I'll give it a try - though not sure how to remove the hot/cold control knobs that are up against the plastic cover.
Most knobs are removed by popping the center off and finding the screw under that. I have different controls, so that is only a guess.2019 T@B 400 Boondock Lite
Remove the screws on the sides of the panel and it exposes the flexible connections. Our 400 had a leak caused by ill fitting flex hoses. The leak may be a result of just loose connections.
2013 Tundra TRD 5.7L
Massachusetts
- 920 Introductions
- 74 Teardrop Groups & Links
