What size screwdriver for Victron terminals? (MPPT 75/10)
jkjenn
Member Posts: 6,417
Does anyone happen to know what the size of the best screwdriver bit is for a Victron MPPT 75/10 controller is?
I have always used the same screwdriver but it is too tight and I need to use a drill to back it out.
@jkjenn, I assume you're asking about the lugs for the wire connections, they're a small flat blade screwdriver no wider than 5/32".2021 T@B 320S Boondock - 2018 Toyota 4Runner
Thabks, I did manage to find a bit that just barely worked. I feel like those terminals are the only downside to the Victron controllers.
- 916 Introductions
- 72 Teardrop Groups & Links
