Zamp to Jackery
dundons
The plan was to charge my Jackery 160 power station with my existing Zamp portable panel that I use for the trailer. I wanted this to work, seemed like a no-brainer, and from the description, just plug and play... I included an SAE to 8mm adapter between the panel and the Jackery.
Not so fast ke-mo sah-bee, there's just one problem- it doesn't work. All the connectors fit together but the Jackery will not allow the Zamp to deliver a charge. Could be due to the solar controller built into the Zamp, don't know. Any ideas out there?
2016 T@B CS/ 2014 Toyota FJ Cruiser
There is an MPPT controller built into the Jackery. You can’t have two solar controllers.Look on the back of the Zamp and using a small screwdriver, disconnect the wires….after you mark which side goes onto which terminal. Hint: one side of the cable has plastic molded lines in it and the other side is smooth.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”2
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
