2018 T@B 400, who makes the *interior*/bathroom shower components?
FrontRanger
Member Posts: 2
Hi folks! I was wondering if anyone might know who the manufacturer is for the shower components in the bathroom of a 2018 T@B 400. The cold water handle decreases water flow to the shower when it's turned clockwise, but doesn't fully stop the water flow and if turned past a certain point flow jumps up. I took out the valve hardware and see a hairline crack in one of the 2 pieces of the valve, but I've been to several hardware stores with no luck finding a matching valve.
I also haven't had much luck getting info from nuCamp I'm afraid. I left a couple of messages, sent emails with pictures, and then when I finally get a part number it's for the exterior shower unit. That mistake is clearly at least partially on me because I could have been more clear concerning which shower I was talking about, but it sure is hard to get hold of anyone there or get a return phone call or email now that my T@B isn't under warranty..
I'd like to replace both parts, but it's the one on the left with the rubber disk/gasket that has the hairline crack (not visible in the pictures I took) that I believe is causing the valve not to close completely.
@FrontRanger - photos too large and deleted. https://tab-rv.vanillacommunity.com/discussion/47/what-size-should-my-posted-forum-photos-be#latest Moderator
Try emailing help@nucamprv.com. It’s the weekend, so no one will see it until next week. Allow a few days for an answer.Verna, Columbus, IN
- 920 Introductions
- 74 Teardrop Groups & Links
