2021 T@B 320S kitchen faucet
Has anyone replaced the 2021 faucet with one that can swivel?  The faucet on the BD allows a 360 aerator to be screwed on but the 320S does not so want to replace the entire faucet.  I know it’s been done with earlier Tabs but don’t know how different this year’s model is.  Thanks!
Aggie/ 2021T@B320S; Alde Compact 3020 HE/ 2021 Subaru Ascent
Rockville, MD (a D.C. suburb)
  • MarkAl
    MarkAl Member Posts: 510
    I agree the faucet should swivel! Now if it could incorporate a shut off as it swiveled! A simple quarter turn valve coupled to the swivel, but requires more mech cleverness than I have to also keep it simple.
    Snohomish WA, 2024 3.6L Grand Cherokee
    managed by VE Smart Network
  • WayneW
    WayneW Member Posts: 260
    We replaced ours with a bar prep sink faucet.  It swivels side-to-side and also has a spray tip on the end that swivels.  We've been very happy with it and installation was very easy.  We have a cutting board that is big enough to span the stove or the sink so we can have more counter space.  The swiveling faucet accommodates the cutting board and gives you working room.  The original faucet was just in the way.
    Yes, you do have to be careful when it's swiveled to the side.  If you accidentally hit the handle you quickly end up with a very wet counter!  A shutoff would be nice but complicates things.
    https://www.amazon.com/gp/product/B08JSQCVF4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    2021 320S BD
    2017 F-150
    Coeur d'Alene, Idaho
  • ZippyA
    ZippyA Member Posts: 59
    thank you so much @WayneW!!! And this is for a 2021, right?
    I won’t be able to do this myself. Is this something a regular plumber could do?  Or maybe I can check with the service department of my dealer. Can’t wait to make the change.
  • WayneW
    Yes, we did that in a 2021 320S Boondock.
    Someone with a basic level of plumbing knowledge could do this. I used the existing water lines. You might get a flashlight and try sticking your head under the sink. Study it, look at the new faucet, and heck, maybe you’ll decide you can do it!  A regular plumber could do this.
    2021 320S BD
    2017 F-150
  • LonesomeRoad
    LonesomeRoad Member Posts: 86
    @WayneW - Any chance of a picture of that faucet installed in your 320? Thinking of doing the same mod on ours. Thanks.
    2021 400 BD
    2018 Ford F150
  • WayneW
    Here are a couple of photos of the faucet and the cutting board that we use as counter space.  The cutting board spans either the sink or the stovetop with the glass down.  I put some stick-on plastic feet on the board to raise it above the sink and stove level.  It makes for a decent serving tray too.  We also put in a stainless backsplash, which is just stick-on tiles from the big orange box store.
    2021 320S BD
    2017 F-150
  • LonesomeRoad
    Thanks for the pictures @WayneW. Definitely going this route with the faucet.
    2021 400 BD
    2018 Ford F150
  • SusanD
    SusanD Member Posts: 87
    @WayneW will definitely be doing this too. And I love your back splash!
    2021 Tab320S Boondock, 2019 Subaru Outback 2.5
  • boiseites
    boiseites Member Posts: 23
    This looks like just what I want!  I need the swivel!!!
  • bjn2
    bjn2 Member Posts: 124
    Sadly it's no longer available via the Amazon link.
    Utah-based
    2023 T@B 320 S Boondock
  • Mickerly
    Mickerly Member Posts: 503
    You may want to try Panther RV Products.
    2018 320CS-S
    "Just Enough"
  • Mobean
    Mobean Member Posts: 76
    I replaced our faucet with elbolillo's recommendation found on this thread.  https://tab-rv.vanillacommunity.com/discussion/14553/faucet-replacement-tab-320-2021#latest
    It works great and still available.  You will need a plumber's wrench to get at the faucet nut under the counter, behind the sink.  It's tight in there but doable.
    2021 320S BD
    2020 V6 Chevy Colorado
