12 Volt Air Conditioner
Tabaz
Member Posts: 2,420
Came across this company while watching a truck camper video.
https://www.cruisencomfortusa.com/
Here is the camper video where she mentions the 12V A/C at 2:25 minutes:
https://www.youtube.com/watch?v=kd6LSJjOawM
https://www.youtube.com/watch?v=kd6LSJjOawM2016 Outback 320
Interesting stuff @Tabaz. Scanning through the install .PDF the only power data I ran across was the need for 4GA wire and a 60Amp breaker for the smallest/minimal install. I wonder what that translates to in current draw or Watts during use. I couldn't see that for a tech spec during a cursory look at the web site, but I may have missed it.
2019 320 Boondock Edge - Sold Jan 20220 -
Looks like 38 to 46 Amps draw @ 12 volts.
Brad2020 400 BDL aka "Boonie"
Concord, NC1 -
A quick glance at their website shows the smallest unit is 5,000 BTUs and costs $4,000. It draws 29 "nominal amps" on low blower speed. Interesting product. Love the idea of a split system for quietness. Not sure if the 5,000 BTU unit is an actual split system like the 8,000 BTU model (about $400 more).2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
Yikes! Power wise it seems Chief Brody's line 'You're gonna need a bigger boat' is appropriate...
2019 320 Boondock Edge - Sold Jan 20221 -
Dometic makes a pretty decent 12v system. RTX 2000 I think. 6200BTU or so. There are a few videos on YouTube. Looks like a regular roof mount unit but much lower profile and pulls 600w or so. Need a good sized solar bank and batteries. I really hope this is the way things move in the near future.2021 400 BD
2020 Tacoma TRD Off-Road0 -
And here is the Dometic mentioned above:
https://www.dometic.com/en-us/professional/truck-solutions/truck-parking-coolers/dometic-rtx-2000-262673
@manyman297 and @Tabaz , I was just looking at those the other week after watching a van install on YouTube. I got all excited until I looked at the specs. The smaller 1000 unit weighs 53 lbs and only allows for an 8 degree tilt. The larger 2000 can have up to a 20 degree tilt but weighs a whopping 73 lbs. I don’t know the slope at the top of our T@bs, but isn’t 53 lbs too heavy a load for our roof?2019 T@B 320 S | 2019 Subaru Ascent1
Yes - it is WAY too heavy for a T@B roof! Saw a T@B a few years ago with a roof-mounted A/C in place of the ceiling fan. Very noticeable sag in the roof. It was not a pretty sight.2016 Outback 320
2024 Ford F150 Supercrew short bed.2 -
I’d assume it would be too heavy. Usually when an RV is “prepped for AC” they’ll reinforce the opening. You’d have to do some serious modifications to the T@B roof to make it work. Plus you have to run the wiring. I wonder if they’ll make a ducted version like the cool cat?2021 400 BD
2020 Tacoma TRD Off-Road1
- 426 Service/Maintenance & Recall Notices
