320 Boondock cover
Nursejoe
Member Posts: 32
Does anyone have any information about a cover that will fit a 2019 320 Boondock with a Yakima rack basket with spare tire? I have seen some discussions about covers but have not found one addressing the spare on the rear rack. Any assistance would be appreciated.
We have a Yakima rack basket on the back of our T@B 320 and use the PahaQue cover which works fine. I put a tennis ball over the bolt mechanism that sticks up from the spare tire so it doesn't wear a hole in the cover.2015 T@B 320 S, 2019 Jeep Cherokee
This is the one we got for our 2019 BDL. It fits like it was made for it.
https://www.amazon.com/dp/B01IU4BE6G/ref=cm_sw_em_r_mt_dp_D46XS4GDQPF3DKZXW3MM(Note, this should not be construed as a recommendation, just an example of something known to fit 2019 with the Yakima rack.)It covers the aft rack just fine. But it won't also fully cover the front tub. Note, since ours is the Lite model, we have the spare mounted in the factory location in back underneath instead of up on the rack, but I'd bet this cover would still work.The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. | -REBEC OF GINAZ2019 T@B 320S BD Lite, Jeep TJUR, Jeep JT -
Thanks everyone for the info
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
