This is how I would change a tire. I have an 8 ton bottle jack from Harbor Freight. I would place it just in front of the flat, under the frame. NEVER raise the body of the T@B using the axle. Don't let AAA do it either.
Make sure the other tire is chocked, and have the T@B hooked up to the hitch on your tow vehicle.
Loosen your lug nuts, raise your jack, remove the lug nuts, remove the tire, put the spare on with the lug nuts loose, lower the bottle jack, tighten the lug nuts.
Put the bottle jack and lug wrench away, put the flat away, remove the chocks from the other side, verify that everything has been put away. Check your lights to make sure they're working.
Now, slowly pull away, making sure once again you have everything.
I had a blow-out on I-70 at 9 pm on a Saturday night last year, and thank goodness for AAA. The semi truck traffic was terrible with their wind draft blowing, and I sure would not have wanted to use the stabilizers to hold the Silver Shadow in place, and now certainly wouldn't want the same for the T@B.
This is my personal opinion, and yours may vary.
How would that work? Does that work with the tongue and stabilizers fully extended?ChanW said:
Others have stressed leaving the tab connected to the (braked) tow vehicle for safety, and that makes sense too.
It will work with the stabilizers on one side extended far enough to slide the tire off. It won't work with the tongue all of the way down. I'm still thinking of a flat tire beside the Interstate and all of the wind from semi trucks. Although Little Guy has given the instructions to use all 4 stabilizers to take both tires off of the wheels, I sure would not be comfortable next to an interstate in this position.
I carry a bottle jack and jack stand in case I need to change a tire. The jack stand is for just in case the jack fails (better safe than sorry). If I'm not on a hard surface, I place some kind of platform under the jack and stand to eliminate sinking or shifting.
I make sure the tires are chocked because it is difficult to find a really flat surface on the frame large enough to put the jack on, so there is the possibility of rolling or slipping. And, try to keep any part of your body out from under the trailer at all times.
Don't have a torque wrench, so just tighten hard as I can, alternating from side to side.
I bought a Harbor Freight torque wrench, but I have to admit that I haven't taken it out of the package. I want to read the instructions because my former neighbor told me I should retorque it, but he always did it for me. By the way, what is the amount I should torque my wheels?
How many got their T@B tires balanced when they got their T@B or new tires? I'll raise my hands. My neighbor's auto repair place did it for me. All 3 of the tires.
Put on new radials this Spring. Tire place wasn't going to balance (trailer tires?), but I insisted.Verna said:How many got their T@B tires balanced when they got their T@B or new tires? I'll raise my hands. My neighbor's auto repair place did it for me. All 3 of the tires.
I didn't have them balanced originally, but have had new tires put on twice now and the shop balanced them each time.Verna said:I bought a Harbor Freight torque wrench, but I have to admit that I haven't taken it out of the package. I want to read the instructions because my former neighbor told me I should retorque it, but he always did it for me. By the way, what is the amount I should torque my wheels?
