Well we just finished our 5000 mile trip out to Colorado in our 2021 TAB400 and I wanted to share a caution for those of you with a Nautilus P3 water system. We have had numerous leaks in our TAB which I have mentioned before. Because of this I have installed water alarms under the bed near the back of the Nautilus. After 2500 miles on the road we were dumping the black tank, and when I started to run the flush, the alarm went off. After pulling the cover to the plumbing area I could see that the fastening collar for the black tank flush had come loose and was letting water drip on the floor. I had tightened all connections before the trip. If you have the Nautilus system I would strongly advise checking and tightening all of the connections on the back of the Nautilus on a regular schedule. It is a great concept, but flawed in either assembly, or installation.
                2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland
0 ·
After a year and 15K-ish miles, not a single leak from my Nautulis panel (2021 T@B 400) - or in the entire camper. And I check that area after every trip when I open the Alde water valves.
Sorry you're having so many problems with that - water is the thing I worry about most as it pretty much destroys everything in its path!
2008 Toyota Tacoma
2020 Tacoma TRD Off-Road
2008 Toyota Tacoma
In defense of Nucamp, I just think the entire RV industry needs an overhaul. Just peruse any Airstream forum and you'll see people complaining about quality issues too. We camped with my cousin this weekend and he rented a Dutchmen something or other and the quality was pretty atrocious. Spray foam hanging off the bottom of the trailer, butyl tape sloppily applied under the windows, etc. We were considering the Intech Sol Horizon but the amount of complaints on one of the Facebook user pages turned me off to them.
It's enough for me to reconsider buying another RV after this. I almost would rather do a camper van build myself.
Can you imagine if Consumer Reports tracked RVs on a regular basis?
