Thornwave Labs bluetooth battery monitor
Remotely monitor two DC voltages, current, power, energy (Wh), battery charge, (Ah) and temperature
With the two DC voltage inputs, one for the ships battery, the other could monitor raw DC voltage from the solar panel.
Internal shunt for up to 60 amps and a max of 60 volts.
I went ahead and purchased it  and received the package about a week ago. I mounted it near the battery switch on my Tab 400 and found it had about 30’ range with the access panel door closed.
A free app is available for both Android and iPhone and I’m impressed with the features.
Will continue to play with the device and report back.
Don & Mary
2018 Tab 400
2019 Tundra CM
Wisconsin
