Can somebody check for me to see if the microwave is on a dedicated circuit? Please and thank you.
Viajero
Member Posts: 123
Hi Folks. We have a T@B on order that won't arrive till April (which is good timing as the new SUV does at the same time). We have some mods planned and it would be ideal if the Microwave was on a dedicated circuit. The easiest way to check is to go to the WFCO breaker panel and see if one of them is labeled "microwave".
Thankyou all in advance.
J and A
J and A
Hi @Viajero, yes the microwave is on a separate 20A breaker circuit (2021 T@B 400 BD) "Microwave (if equipped)"
2021 T@B 400 BD T@bitha with 2016 Highlander
Juliet and Andy in Massachusetts -
Thank you newbies. So to confirm, it is the only thing on that circuit right? (My bad, i should have worded it that way to begin with).TABNewbies said:Hi @Viajero, yes the microwave is on a separate 20A breaker circuit (2021 T@B 400 BD) "Microwave (if equipped)"Thanks again. -
Correct, I knew what you meant. Aside from me attaching shore power and checking the breaker on / off that nothing else is impacted, the microwave appears 99% to be both labelled as such and on its own breaker and other items are on other breakers.
Picture:
Thank you again. That’s what I needed.
- 917 Introductions
- 73 Teardrop Groups & Links
